Vacuum Hoses
Vacuum Hoses
Is there a good kit or source for the larger vacuum premolded hoses under and around the intake manifold for a '86-944? I'm doing belts and want to update these old rubber items.
there is this kit on 944online: http://944online.com/cgi-bin/ASI_Sto...ystem-944turbo
Lyndsey Racing:
http://www.lindseyracing.com/LR/Parts/944SILICONE.html - random silicone pieces
http://www.lindseyracing.com/LR/Part...ACUUMLINE.html - plastic hard line replacement kit
http://www.lindseyracing.com/LR/Parts/HOSEKITS.html - Venturi/Delete kits
Or, order raw silicone hose from here, and cut to size of the hose that you are replacing - which is what I did - http://www.boostcontroller.com/ - these guys are in Buffalo (1 hour drive from me) - so to you it would get the next day; hose sizes can be 1/2, 5/8, 3/4; I think I ordered about 10ft of each and that was MORE than plenty
Lyndsey Racing:
The 944online kit was nice because it included new connectors for some of the lines that connected to some fuel items like the fuel pressure regulator and damper. It also included manifold gaskets if you want to get underneath the intake manifold, and a new venturi. I used the kit for my 85.5 NA. I ended up needing some additional hoses for some other pieces I wanted to replace.
