Washer for Reference Sensors and Checklist before firing her up?
Is there a washer that goes between the reference sensor (one nearest front of engine)and the mounting block? Just wondering as I will be starting the engine for the first time tonight after R&R the belts, vacuum hoses, seals, rollers, FPR, etc.
Can anyone think of anything else to double check?
Thanks!
Thanks!
The rear sensor has the D shaped spacer, the front has nothing
If you moved the bracket, you will need to index it properly. Attach a .8mm washer onto the end of the front sensor with light glue and place it into the hole. Adjust the bracket so the sensor bottoms out and tighten it down. Remove the sensor and washer, clean off glue, and re-install.
