"Squeak - squeak" on start-up????
Just had new timing belts, two rollers, waterpump (re-built), etc installed on the car 1800 klms (around 2700 miles) ago. I'm obviously due soon for a re-tensioning.
Started the car yesterday and heard two very quick high-pitched "squeak" noises that went away right after I heard them. It did this twice in one day. It only happened on start-up.
Could this be a starter thing? Or is it the belts?
I will also say I had just finished washing the car just before it did it the first time and then it sat for about 4 hours and did it again on the start-up after those 4 hours. Hasn't done it since (about 8 or 9 start-ups).
Any ideas????
I'm going in today for the belt re-tensioning
..... just incase.
944S Boyeee
Any ideas????
..... just incase.
944S Boyeee
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Squeaking alternator or power-steering belt. If it squeaks when you turn the wheel, it's the power-steering. Tighten up the tension rods. Put out some mice traps ! <img src="confused.gif" border="0">
Thanks Danno,
That was my first guess. I figured the timing and toothed belts couldn't really "squeak".
Another question.....do the a/c and other smooth belts have to be re-tensioned at the same time as the timing belts??
Also, how long should a belt re-tensioning take??
The mechanic said it would be "an hour/hour and a half" - how close is he????.
944S Boyeee
944S Boyeee
You know, I have an interesting squeak that I haven't been able to locate yet.
When I start her up cold, no squeaking, but as soon as I press the clutch down, I'll hear a squeak squeak squeak that goes until I let up on the clutch. Only does it when the cars cold.
As an aside, I used to have a SQUEAL on start-up, was the power steering pump. Tightened up the belt, sounds great.
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
"When I start her up cold, no squeaking, but as soon as I press the clutch down, I'll hear a squeak squeak squeak that goes until I let up on the clutch. Only does it when the cars cold."
Uh oh... now THAT would be the pilot-bearing!
Hopefully whoever did your clutch last replaced that one. Would hate to go through a clutch-job just to replace an $11 bearing...
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Mark,
Does the squeak you hear when engaging the clutch sound like it's coming from the back of the car?
Mine does this. I have a sound similar to a roller squeaking, but it's not coming from the engine area. When I push in on the clutch, and start moving - I get a squeak now and then.
I dunno???
944S Boyeee
I dunno???
944S Boyeee
Clutch...hmm, not sure if that has been done, ever.
It sounds like its coming from right in front of me (when I'm in the driver seat), and that's about all I can tell.
Pilot Bearing eh....all new clutch job you say? What happens if I just let it go bad? Will it only do this on start-up?
P.S.
Danno - Don't EVER SAY UH OH TO ME!
You know I 'bout **** a brick when I saw
Danno: Uh Oh
that just aint cool man. Next time, before you say Uh Oh, say: "Are you sitting down? Are you not wearing pants, cause you're not gonna wanna ruin them, but, Uh Oh."
Danno: Uh Oh
