Insulation Around Catalytic Converter Loose
I'm assuming that what I'm looking at is a sound and heat insulation piece around the catalytic converter. Well after hitting a couple of cattle guards, it came loose and was hanging down. As a temporary fix, I wired it back together and it holds together just fine now.
My question is this: What exact purpose does this piece serve, am I right in thinking it's sound and heat insulation? Also, has anyone else had an issue with it coming loose hanging down? If so, what was done to correct the issue?
