mounting a 6-point harness with Redline roll bar in early car
Tip: Masking tape the washers together and include a little "tab" so you can hold the washers in place while you push the bolt through.
here's another question:
I'll be bolting the new sliders through the floor, like Joe did - so I'll be drilling right through the floor in the stock seat-mount locations
there are these "nuts" or something inside, and they are not secure in there, how do I drill through them?
just looks like if I use a drill, and with that "nut" loose inside, its going to just spin with the drill, there is no way to "hold" it in place
Greg - I'm also going to use "plates" under the floor of the car like Joe did ... and I'll have the back seat mount points taken out and square tubing welded in their place at a later point in time; going to make this as "secure" as possible
yeah, I tried to "pry" it out of there, no luck
I could use a HUGE drill bit to make the opening a little bigger, maybe? just to take some of the surface off
so I am doing this right now
I am drilling holes through the floor for seat-mounting
I am "prying" the tops of the nuts that hold the bolts that bolt the seats down - making the hole larger, taking the nut out, then closing the hole
I will probably use small metal plates and big washers at the points where slider bolts to the floor
yup
I need to figure out how long the new bolts should be (going through the floor) - the ones I have @ home appear to be about 1" too long
going to run out to Lowe's and check what they have
This is particularly true for the sub-belts. The sheet metal under the middle of the seats is incredibly thin and soft. I've seen washers used (and recommended) for sub-belts, and to me that only works if you don't ever plan to use the sub belt! It would not take much to pull a big washer through your floorboards. I have a 10" x 10" plate under each seat.
I was thinking of making small plates for each bolt, and 1 big washer and a smaller washer
I got the holes drilled on the driver's side for now - tried to fit the slider, and slider fits on perfectly
now I'm going to run out to Lowe's (since I live like 1 mile away) - and pick up a few bolts that are 1/2" shorter then what I have now
the bolts I got now to bolt the slider to the floor stick out by like 1 1/2"
what size bolts did you guys use? the ones I got are like 1/2" round and like 4" long
too long isn't an issue. just dremel or hacksaw off the end and clean up the thread :P
