Fuel pump (+) wire
Fuel pump (+) wire
On my 85.5 I'm trying to locate the fuel pump (+) wire. The schematic says it is Green/Blk but has a connector somewhere between the DME/Fuel pump relay. Anybody know where this is exactly?
I've completely disconnected the Porsche DME as I have the 5.3l PCM and the only wire I want to re-use is the hot wire to the fuel pump as I am not using the Factory relays.....
