Do you install "anti-squeal" pads with your brake pads?
I'm about to throw some MetalMaster brake pads in my car and was wondering if they should be installed as is or should "anti-squal/dampening" pads be put on the backs of them? Will one way offer more "feel" or responsiveness than the other?
I have non-M030 front calipers from a 968 - rears are stock.
I wouldn't install the anti-squeal backing with them.
I have KFP intermediate pads installed without the quieters, and have learned to live with the sound, and with people telling me I need new pads.
-Z.
-Z.
Lifetime Member
Lifetime Member
[quote]Originally posted by Z-man:
<strong>I wouldn't install the anti-squeal backing with them.
-Z.</strong><hr></blockquote>
Z - why not? I had some of that sticky stuff put on the backs of my pads a while ago. It may need it again because I had 'em out the other day and it's starting to squeal. Does it hurt the braking performance?
Just curious.
-Matt
Just curious.
-Matt
[quote]Originally posted by Matt Olde:
<strong>
Just curious.
-Matt</strong><hr></blockquote>
I'm more concerned about braking than anything else. The more stuff in the calipers, the greater chance of something getting moved out of place.
We are talking about the pads (size of the brake pad backing with the round thingies on them, that go between the brake pad and the pistons, right?
-Z.
<strong>
Just curious.
-Z.
I simply re-use the ones I have with a little of the anit-squeel paste used instead of the factory adhesive. Don't think it really affects performance in any way, but I could be wrong. My brakes have always felt fine. I also use MM's on my car.
As for moving around, since they insert into the brake piston, I do not think they will move very much....
My $.02
My $.02
Lifetime Member
Lifetime Member
[quote]Originally posted by Riff:
<strong>As for moving around, since they insert into the brake piston, I do not think they will move very much....
My $.02</strong><hr></blockquote>
Mine move around. The move forward and back, at least one pad on each side, creating a clicking noise that sound similar to a CV joint gone bad. I removed them, put some cloth tape (small pieces) around the outside of the pad, and slid them back in. No noise. The only problem is I have to do this every 8 months or so when the tape wears out. I just did it last weekend, why it's on my mind. I was getting tired of people looking at my car not for it's good looks, but because I sounded like a retard with my wheels clanging.
-Matt
-Matt
Matt-
Are we talking about the vibration dampners or the actual brake pad? I was talking about the vibe dampners that are on the 4 piston brakes.
Cheers,
Cheers,
I use the stuff that you spray on the back of each pad. It does a good job of eliminating the squeal, and I don't believe it has any detrimental effect whatsoever on the braking.
