No HVAC temp control -- hints, tips??
Everything works with the climate control, except for the temperature settings. Since I got the AC fixed, everything works fine. I can move air to the defrost, recirculate, feet, and panel. If I want heat, then I have to unhook the famous "rod" under the drivers dash. The heat works fine, I just have to control it manually. Also, the AC runs almost continuously...because there is nothing telling it the cabin is cold enough. Its not a problem in 100+ heat here...but I don't want to damage the system either.
Any ideas on what to look at?
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Check out the link below for heater malfunctions. You have temp sensor located near the firewall passenger side. The little round disk next to the cigar lighter has a tube attached going back to the temp. sensor. I believe it is a bi-metal strip.
http://www.clarks-garage.com/shop-manual/hvac-01.htm
Cheers,
Larry
Cheers,
Larry
Thanks Larry, but I've been through everything that clarks garage talks about.
But, I am on the fence about the temp sensors. There are 3 of them. How do you test them?
Also, has anyone come up with a way to test the climate control unit? I remember there was a thread about it a while ago, but IIRC nothing came of it.
1 Post
I replaced my control unit because the AC switch was broken. Got one off ebay for $40.00and it works great now. I could not see paying $84 for just the switch and have to take and de-solder the switch to put the new one in. I don't know if anyone has been able to test the control unit. Most just take a chance and buy a used unit. Plyhammer normally has good stuff and ships fast. I hope you can get it all sorted out. I know how frustrated you can get.
Cheers,
Larry
Cheers,
Larry
