Car overheated - what am I missing.
1 Post
I recently had an overheating problem that turned out to relate to the fact that the PO had apparently replaced the waterpump with the $40.00 variety with the plastic impeller.
The impeller's vanes were almost completely gone....it would move enough water to idle cool but at 60mph for any lenght of time it would overheat.
Interestingly enough...at 80mph it would run cool enough to drive and that is how I made it home!
Note that while overheating it would blow cool air from the dash because no water was circulating.
I guess that's why the temp and low oil pressure seem worrying.
Man, I could not get up to the last line in 50 deg weather if I put a sheet of cardboard in front of the radiator! I think either your thermostat is stuck or defective, or your radiator is plugged (airside or water side).
1 Post
Well I've verified that both the upper and lower radiator hoses are hot, so would that indicate that the thermostat is working correctly? Or do I not have a clear understanding of that... (very possible)
As hard as it is to get air out of the system, it could be just as hard to get caustic or acid out of the system using d-i-y stuff. It's surely safer to take the rad out, and honestly not that much work. Shops have much better chemicals than you can buy over the counter. But while it's out, you have a golden opportunity to get at the thermostat...
1 Post
OK!
Update. Its no longer overheating. I took the radiator out today and flushed it, and blew out tons and tons of sand and crap and who knows what else from the fins. Put it back in, filled it, bled it, and drove it, and its doing fine now.
HOWEVER. I seem to have damaged the thermofan switch in the process.
The fans never turn off. I have to either pull the relay or unplug them at the switch - which is tricky when the fans are running...
Is it ok to drive the car until I can get the thermofan switch replaced? Is there anything else it could be?
BTW thank you everyone for all your help on this. I really appreciate it.
