lost the ball
Took the fuel rail cap off and heard something fall. Didn't realize till later that it was the ball bearing inside the cap used to plug the rail. Anyone know what size bearing is supposed to be? Don't want to order a replacement from the porsche dealer for a five cent bearing.
Storch
1986 944 na
Storch
1986 944 na
I had the same issue, not expecting a metal ball to fly off the fuel rail. FWIW, I tried attaching the nut without the ball, and it leaked when there was fuel pressure. I was lucky enough to find the ball.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
SIMPLE, Use your Shop Vac and clean your floor at the same time. You will hear when it gets sucked up in the vac, dig it out and finish cleaning the floor. If you were outside use a magnet.
Cheers,
Larry
Cheers,
Larry
