radio install wiring help
Old 06-01-2010, 11:18 AM
Dan151
Dan151's Avatar
Default radio install wiring help
83' 944 N/A
i hooked up the speaker wires fine but cant figure out which wires to connect to get power to the radio? PO hacked up the wiring so im kind of confused right now
got this from another forum is everything correct? i dont have an orange wire coming from my new radio
ˇ brown speaker wire with red stripe marked "black – right" goes to gray wire,
ˇ plain brown speaker wire marked "black – right" goes to gray wire with black stripe,
ˇ brown speaker wire with red stripe marked "white – left" goes to white wire,
ˇ plain brown speaker wire marked "white – left" goes to white wire with black stripe,
ˇ small red power wire with fuse marked "permanent 12v" goes to orange wire,
ˇ small whitish power wire marked "antenna power" goes to blue wire,
ˇ large red power wire marked "ignition 12v" goes to yellow wire, and
ˇ large brown power wire marked "ground" goes to black wire.
Old 06-01-2010, 04:33 PM
Dan151
Dan151's Avatar
bump
Old 06-01-2010, 04:38 PM
75ohm
Resistance is Futile
75ohm's Avatar
You own a multimeter?
Old 06-01-2010, 05:43 PM
peanut
peanut's Avatar
its clearly been hacked about by the previous owner and none of the wires are likely to be original so a Porsche schematic is unlikely to help.
If you don't have any basic electrical knowledge and multimeter testing skills I would strongly advise you to take it to an Auto Electrician and get them to wire it up for 30-40 bucks or whatever and get a proper job done that won't fry your wiring
Old 06-01-2010, 06:54 PM
Dan151
Dan151's Avatar
can anyone tell me where the red/blue wire and the red/yellow wire with the fuse go?
Old 06-01-2010, 06:59 PM
Dan151
Dan151's Avatar
yes i do!
Old 06-01-2010, 08:08 PM
75ohm
75ohm's Avatar
Originally Posted by Dan151
yes i do!
Where are you pulling 12v switched and 12v constant at?
Old 06-01-2010, 08:21 PM
CPR
CPR's Avatar
red/blue goes to the radio relay~which comes from the ignition switch (to one side of the relay) AND from fuse #7 in the main panel (to the other side of your relay).
red/yellow with the 2.5amp fuse, actually comes from your tachometer power loop.
Old 06-01-2010, 08:27 PM
Dan151
Dan151's Avatar
the red/yellow wire with the fuse in it is the constant and the red/blue is switched!
coming from the harness on the radio is a larger yellow wire and a smaller red wire
along with two purple and two green wires which im assuming are for accessories.
Old 06-01-2010, 08:30 PM
Dan151
Dan151's Avatar
yeah the readings i got confirm your statement the red/blue is indeed the switch wire because its only reading 12v when the ignition switch is on.
75ohm
75ohm's Avatar
So are you ready to fire up the head unit?
Old 06-01-2010, 09:51 PM
Dan151
Dan151's Avatar
what do you mean by that?
Old 06-01-2010, 10:05 PM
75ohm
75ohm's Avatar
You have your connections sorted - so are you ready to power up?
Old 06-01-2010, 10:13 PM
CPR
CPR's Avatar
lol...That is why I told you, so you didn't have to check
Old 06-02-2010, 12:38 AM
Dan151
Dan151's Avatar
ill give it a try in the morning, found that the fuse was blown on the red wire so will replace that with a spare and hopefully all goes well. will keep you posted!
haha i came up from the garage after you posted that
Quick Reply: radio install wiring help
