Check Out My NEW Shifter!!
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
you all would be amazed what a huge difference those rubber bushings make on eliminating vibrations...
i will miss not having that rubber in there.
I disassembled everything yesterday and that pin was chewed to $hit and was barrel shaped badly, I'm surprised the E-clip was still holding. Anyways I mic'd the inside of the shifter rod and it was not as worn. I think Delrin would be an ideal isolator in there.
Also, it looks like the stock parts can be modified to shorten the shifter **** AND keep those rubber bushings.
