Air/Vacum leak?
Air/Vacum leak?
I think I might have a leak somewhere. Car starts easily and idles smooth at around 800 rpms for about 30 sec or so. Then the rpms fluctuate some. Drop down to around 500 and back up. Car revs smooth when you get on the gas. You can hold it at higher rpms and it runs nice and smooth. Let back off and it starts fluctuating again. The mpg meter fluctuates with the rpms too. Where should I look for a problem? How should I check for a problem? I just changed all the plugs, wires, distributer cap, rotor. I was thinking that it probably is a small air leak or something? Car has chip, k&n filter (stock replacement), magnaflow muffler and cat. Could the O2 sensor need replacing? Don't know if it has ever been replaced? TIA Lots of knowledge on this board. Great help for a newbie like me
