OIL EVERYWHERE!
#31
If it's not the sender, and oil and coolant are mixing, then an oil cooler re-seal job is in order. This job is a huge pain if you have the later 2-piece oil cooler heat shield. Be sure to get the shims and seals EXACTLY right or it won't stop the mixing. I had to do this job twice.
'87 doesn't need the oil pressure relief valve alignment tool. The newer valve is self-aligning. I think '87 got the updated valve.
Bryan
Bryan
#33
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by doyle:
<strong>Hey Schlag,
What mechanic from South Jersey? I am just curious as I have also had a botched job from a well known SJ mechanic.
doyle</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I just sent you a PM with the info.
<strong>Hey Schlag,
#34
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Bryan:
<strong>If it's not the sender, and oil and coolant are mixing, then an oil cooler re-seal job is in order. This job is a huge pain if you have the later 2-piece oil cooler heat shield. Be sure to get the shims and seals EXACTLY right or it won't stop the mixing. I had to do this job twice.
Bryan</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Is there a way to tell if it's the 2-piece via series of VIN#?
I looked at the procedure and the job doesn't
look too bad, I will be careful though.
Any pointers on clearing all that muck out of the cooling system?
