I just love porsche reliability
So i went to elliot's house tonight because i had planned to go by and look at his cars anyway. SO i took my dad's 928 down there, and he had a spare 87 lying around. so he let me borrow it. I plugged it in, and it started right up. So i'm eaither using mine if it works, or buying his. His red 944, and his 951 are great BTW
So i'm taking the 928 to school tomorrow, and cleaning out the tray when i get home.
Rain water by itself is a poor conductor. Add salt or acids and that changes. As stated, you need to dry out the water inside the DME. If you don't want to open it up, put it in the oven at 100 -150F for several hours. Then let it sit in a warm location for a day to make sure all the moisture is out of the case.
If you do pop the top off of it, wash it (just pour it all over the boards) with 99% Isopropyl Alcohol and let it dry in a warm location. Alcohol absorbs water like a sponge and also dries quickly. No need to wipe off the alcohol, just shake out the excess and let it dry.
If you do pop the top off of it, wash it with 99% Isopropyl Alcohol and let it dry in a warm location. alcohol absorbs water like a sponge and also dries quickly.
I've rocked the roll back too recently
And I think I'll contribute to the theme of this thread...
90% of the problems with these cars exist between the steering wheel and seat.
Its a 20+ year old German car.... period. Either you are prepared to do the maintenance or you're not.
I'm not trying to be an *** but cmon. The NAs especially are EXTREMELY mechanically sound. Keep up on the little ****, and it will go half a million miles.
IF you want to weld the hood shut on something, sell the 944 and get a honda. I know "surprises" happen now and then, but even those can be greatly minimized by just keeping up with the work load.
(I'm sensitive about my baby! lol)
Drill a drain hole in that battery tray, and your fusebox tray. Some dipwad sealed up the drain holes on my S2 before I bought it, and I'm not kidding, they resealed the whole tray and didn't have half a mind to open up the holes they had covered. It rained one night and I had to drive my car home. First thing that started happening was my headlights started flipping up and down, open close, open close, and flashing like crazy. My clock started flicking on and off, and my dash lights started flashing on and off like the damn car needed an exorcism. Popped open the hood and found a six inch pool of water over my fusebox.
Moral of the story. Check your drains. If there's no hole, a simple .22lr through the tray should do the trick.
If the PO just slapped some bondo in there I suggest stripping the entire compartment down to the bare metal, remove any rust, either weld any holes back up with sheet metal or fiberglass and seal it well. Otherwise you could end up with more annoying problems in the future.
Under the Radar
After that, transaxles just fall apart, rod bearings are worn, the clutch will need another change, and the "little" things aren't so little anymore.
