FS: SBC 385 stroker short block and heads
I know this is not P car stuff, but figured someone might be interested for other projects. Chevy 350 4 bolt main block with Scatt 9000 series internally balanced 3.75 stroker crank, 6" Scatt I-beam bushed rods, and Mahle flat top pistons. Block has been decked and preped. Rotating assembly is fully balanced. Includes new custom grind cam with 107 LCA, 258 I 264 E and .556 lift with 1.5 rockers and double roller timing chain. Block was bored 0.040 over. Fresh from the machine shop. $2500.
Heads are 23 deg cast iron RHS with 50cc cambers and 220cc intake runners. Full race 5 angle valve job with Comp Cams springs, retainers, etc. Valves are 2.02 1.6 stainless. The heads are also fresh from the machine shop. $650
Will sell both together for $2800. These heads on the block will produce 13:1 compression. Located in Western CO. Call me at 9706265975 if interested or e-mail me at jenintmk3 @ yahoo.com (remove spaces)
