Toneau cover part.......
needed! Anyone with a cover for a 924S. I need the left side housing-as you are facing the rear of the car,the cap that goes on the end to hold the non spring loaded post.Anyone not using their cover I could use this piece! I use it to cut the glare from the light colored carpet,hard to see out the rear and the cover helps that! THX! D <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Done With Sidepatch
Try the dealer...Maybe it is reasonably priced (I can dream)...See the image below for the part number, etc...
<a href="http://boards.rennlist.com/upload/Rearcoverpart.jpg" target="_blank">http://boards.rennlist.com/upload/Rearcoverpart.jpg</a>
Guys, I went to the dealer first and they can't figure out which of the two it is- 17.5mm or 16mm, there are two of them and I measured the rod and it doesn't have either size it came up a little larger than the 17.5 so I am as they are puzzled! It is OEM. The cost is 19.95. Mike the one you highlighted is the larger one and if you drop down you will see the other cap labeled #2. That is what is causing the confusion! So they have to order it and just want to get the right one. They don't like ordering a part they will never sell and Porsche wont take it back if it is the wrong one! Very few Porsche's in Des Moines and only one 924S!.....mine! Thx! Peace D! <img src="graemlins/a_smil17.gif" border="0" alt="[blabla]" />
