HELP!
Old Apr 28, 2010 | 12:06 AM
Tayloray's Avatar
Tayloray
Default HELP!
So i was trying to figure out what was wrong with my car, and in the process, i took out the MAF sensor, and cleaned it. then re-installed it. I took my distributor cap off again, and found that the button had a crack all the way up it. so i went, and found a new one at auto zone. Got it on.
When i went to start it, it fired, and run for about half a second, then dies. It couldnt be the ditributor, so i unplugged the maf, and fired it. and it did the same thing. so i re-installed if about 3 times, now result.
What could this be?
Old Apr 28, 2010 | 06:44 PM
luftpirate's Avatar
luftpirate
What was the original problem?
Old Apr 28, 2010 | 10:30 PM
Jay W's Avatar
Jay W
Plug wires back on in the right order?
Old Apr 28, 2010 | 10:52 PM
75ohm's Avatar
75ohm
Resistance is Futile
What exactly did you clean the MAF with? Please tell me it wasn't brake cleaner or carb cleaner...
Old Apr 28, 2010 | 11:06 PM
Yarf's Avatar
Yarf
Check the AFM with this procedure
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk
Take a deep breath and take your time, good luck
