fuel pump current draw
Big thirst, Sore Thumbs
Napoleon
Napoleon
Got a fluke?
Unplug it. Put a jumper in for the ground leed. Use Fluke to jump the + lead. Have some one put car in run position.
If the fluke is on Amps. Viola.
[quote]Originally posted by SoCal Driver:
<strong>Fuse on early 944's is 16 amps. Also provide current to the heating element in the idle valve.
Fuse 0n later 944's is 15 amps.</strong><hr></blockquote>
Actual constant draw should be less. I have a spare fuel pump in the garage. I'll check it's placard to see if it has a value for full load amps.
