Crank Pulley Bolt removal
My project is turning into a real big project. Got her all together and she started on the 4th try. WOOT!! A few minutes later huge cloud of white smoke out the back.
Well start taking her apart again and got to the crank pulley bolt and it will not break free at all. Anyone run into this and how did you end up getting it out without breaking it off in the crank.
I used a 5 foot pipe on a breaker bar to get the crank bolt out of the 968. The PO or their mechanic had it way too tight. Keep in mind that my breaker bar has a sticker right on it saying not to use a bar to lengthen it because it would break and hurt someone. So be very careful if you use a super long bar.
re
Going to give it a shot tomorrow. Took a few days off to work on her.
TY. If I can figure out this MAC, I will post up some pictures of it together before starting over again. Windows laptop died, so wife wanted a MAC... Kill more than the car is right now
So.....I'm at the track for the first time today....Autocrossed my car a couple times and it ran great. Well first lap and boom. I guess my crank bolt came loose. (I've never touched it, I guess i should have).
So i lost my alternator, power steering etc...The crank pulley and bolt/washer, and steering pulley were gone.
They were kind enough to give me the parts and so i got the balance shaft pulley and power steering pulley back. The car will run but quite a bit of ticking. Maybe from the valves??? who knows. But the timing belt was in good shape and from what i can tell it didn't skip a tooth. When i cool down i will take a closer look. Anyway is this the first you guys have heard of this? Kinda bummed me out cause my first track event and figured it cost me $500 after hotel, gas......
