Something Broke Off Again!
Hello All,
While replacing vacuum hoses this ol dried up piece broke off.
Anyone know if the car is drivable to locate a replacement part?
T.I.A.
T.I.A.
Looks like you will have a vacuum leak, and at the brake booster no less. If your not turbo, then plug it off with some duct tape or sufficient. The car will not run/idle very nicely with a vacuum leak.
Other than creating a massive vacuum leak at the brake booster I dont see a problem. Oh! there is that whole stopping thing! Maybe test drive it in a parking lot first and be sure you have sufficient braking power before taking her on the road.
Get a pick or scribe and clean out the broken part in the hole. If some tiny parts fall in the booster it's ok. Then get a plastic vacuum fitting that fits and stick it in the hole and re-attach your check valve. No big deal.
