Need Help with Relay Part Number for 81 931
While trying to repair the cooling fan problem on my 81 931/924 turbo I discovered that the four pin connector relay was installed. Based on the schematic in Haynes, the relay for A/C equipped cars should be 5 or 6 pins. The Parts and Technical manual only shows one relay (4 pin). Could someone with a PET check to see if a relay other than part number 141 951 253B is listed for A/C cars?
Thanks,
Dennis
Thanks,
Dennis
Mike,
Thanks. The part number listed is a simple on/off relay used on the 924 for about 5 systems (horn included). Were you able to find the part number for the cooling fan relay?
Thanks again,
Dennis
Thanks again,
Dennis
