Head question.....
what is the diffrence between the 944 and the 951 head,cam,valves. Are they by chance interchangeable as a whole setup between the 2. I dont want to sound stupid just want some info. I know nothing about the 951 setup.
The turbo also has different valve springs, cam, and port sizes. You can mix them but usually we mix parts more than anything. N/A guys like turbo springs, turbo guys like N/A head castings because they can port the exhaust side (so long as they have everything ceramic coated).
So I could take a complete N/A head, port the exhuast, ceramic coat it, change out the springs cam and exhuast valves and it would be good to go on a turbo? The manifolds (exhuast and intake) bolt up the same and it bolts to the block the same. Would I need to find a both the cam and cam houseing from a turbo or could I just change out the cam itself.
My problem is I am going to need a complete turbo head (head, cam , houseing) and I am trying to decide what would be more cost effectave. Trying to find a turbo one or picking up a cheep N/A setup and converting it.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Buying a used 951 head is more cost-effective at $150-200. Converting a 944NA head would cost quite a bit more since sodium-filled exhaust valves are around $100 each. Then add in a set of valve-springs for $150, ceramic-coat is another $125, labor, shipping, etc.....
Hmmm, I thought the cam was the same for the 944 and 951. I replaced my stripped cam, housing and all, with a complete housing from a N/A, and I haven't noticed the slightest bit of performance loss. It might be there, but not from seat of the pants. Is the cam different? I've been told they were identical. I would like to see the lift and duration specs from one to the other and see what the differences are.
Ditto that.
Anyone with specs on the N/A cam, Turbo cam, and your adverage performance cam please post. That would help out quite a bit.
Part numbers are diffrent, and I think there is more overlap in the NA cam... IIRC.
Danno had some charts on his site at one point.. again, IIRC.
Let me see what I can find.
well there ya go.....when I replaced my cam housing with one from an n/a, a tech at a Porsche dealership told me the cams were identical. I guess the best thing to do would be to buy a mild cam and new lifters and put them in my old housing and switch.......again. At least the housing gasket is only a month or two old, it took an hour and a half of scraping to get the old one off without scarring the head.
any chance of anyone getting lift and duration from those part numbers? It would be interesting to see the diffrence between the turbo and na. Turbo probably stays open a little longer on the exhaust and drops off sharper on the close. Dont know.. just guessing.
Yup, the 951 has the same camshaft as the early 944NA cars. The spec book I have is an '88 version, so I only listed '86-88 951s as having those part#, but I'm sure ALL the 951s had the same cam. And there's only a minor difference between that cam and the later 944NA; about 3-5 degrees of duration and that's it.
One good upgrade would be the Elgin Cam's 'improved' stock grinds. Similar specs to stock, but they change the ramp-up rates to give you more average lift. You end up with a car that's got great ooomph in the mid-range with a wider torque curve and is quicker, even though peak HP/TQ numbers don't show it.
