83' 944 oxygen sensor replacement. ECU reset?
The ECU (DME we call it) is too dumb to know if the O2 Sensor is even in the car. If it gets a single it will use it. If it does not get a n O2 single the car will run just fine. Emissions may not work perfect and it may use more fuel, but the car will still make power.
So in short No.
So in short No.
Small Business Partner
Just to confirm - the DME does not have any non-volatile memory. So there is no need to 'reset' anything. The DME is automatically 'reset' each time you turn off the car.
-Rogue
-Rogue
