Door Sag Solutions?
My driver's door is sagging a bit and I'm looking for suggestions on how to fix it. The amount of sag is enough that I can feel the door drop a little when opening it, but it's not a big problem. Hopefully there's a relatively simple fix (or bandaid) that I can do without removing the door.
Thanks,
Paul
Thanks,
Paul
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by SidViscous2:
<strong>Sadly I think you will have to pull the door.
Sounds like worn door hinges.
Usually a Ford problem.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I hardly know anyone with an '80's camaro that doesn't do that as well.
Be glad that you don't have door problems like I do
Not too sure what exactly happened, but my passenger door has a big glob of weld on the top hinge and the door is difficult to close. I am guessing youever did the butcher weld job did not align the door properly.
