How to disable factory Alarm ?
Well, I've had enough of the friggin factory alarm!
Went out today (after a too long winter) to reclaim the car from storage and it started up just fine had it running for about 5 minutes then shut it off for a few minutes to move some stuff that was blocking my exit.
When I got in the car I noticed the red LED glowing on the central locking switch (no idea how that happened.) When I turned the key in the ignition the alarm sounded and wouldn't shut off until it timed out. This happened several times with the guy who owns the storage facility watching this performance.
It's as if somehow the alarm is set, but there is no way to disarm it.
The car is an 89 951 and the alarm is from the factory. I don't have any real need for it and it's more of a pain in the butt than anything.
Is there some way to permanently disable the system?
Frown
Frown
You could pull the fuse I guess..
I think that the central looking and rear hatch is on the same fuse.. I could be wrong since it was a while ago I messed around with it..
