Billet Diverter Valve
Hey, Scott... could you provide some feedback on the diverter valve? Perhaps quantify how it's better than the OEM unit? I keep hearing that it's an improvement (mostly from the VW 1.8t crowd who use the same valve as us) and just wanted confirmation from someone I know.
The main difference is that its got a metal piston in it, so that you aren't going to have to worry about it failing in the same manner that the OEM one does. My OEM CBV tested fine with a vacuum pump gauge, but I noticed an improvement of .05 bar in peak boost when I installed the Forge CBV that I got from Steve.
Regards,
Regards,
