Rebuild help
Rebuild help
I recently bought my first porsche, and my first car, at the age of 16. This summer the car, a 85.5 944, has pretty much been my life... and a lot of trouble.
I bought it with a blown head gasket, so i popped off the head, only to find a broken ring and terrible scoring in cylinder 4.
So... I dropped the engine out of the car, and stripped it right down to the block. I knew that the block was aluminum, but I was told that there were steel sleeves in the cylinders. And I brought the block to a machine shop to have em bore all the cylinders .5 mm over. But, the cylinder wouldnt clean at .5 mm, so i asked them to sleeve all 4 cylinders for me. But the shop took 3 weeks to bore 1 hole and they said it was gonna be 2 more weeks to sleeve all 4 cylinders. And they were all ********. So i told them to forget about doing my job, and i'll bring the block somewhere else.
If you live in the central New York/Capital Region NEVER EVER bring any machine work to Haberecks Auto Diesel Machine!!! They are the biggest cobb artists in the business! <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Anyway, i broght it to another shop... and the guy told me it is nearly impossile to sleeve aluminum with aluminum.
So, to get to the point, I bought a lower half from Part Werks in Chicago. It is used and it was pretty cheap. What should I do with it?
Chang the bearings?
Or do a whole rebuild with rings and such?
...and the moral of the story is:
do not overheat your 944!
Chang the bearings?
We have been sleaving blocks for many years. If you want to go that way and get higher displacment at the same time take a look at our website or give us a call. He is a pic of one of our 2.8 ltr 106mm Big Bore motors.
