Adhesive to glue vacuum hoses to rubber splits
1 Post
I noticed a vacuum hose (3.5 mm OD) got disconnected from a 3-way rubber split on my 944 (1983). This happened after I had noticed the brake booster giving not enough assistance... I put the hose back in, but would like to make sure it doesn't happen again. What adhesive should I use? I thought contact cement, but it might not be good for the sensors, etc., a sensor-safe non-hardening gasket maker? These hoses are made of plastic-looking stuff.
Thanks, Stan
Thanks, Stan
If its one of the rubber threeways and the small hard plastic line then I use a small black tywrap or two. It works on the turbo. When the three ways get old they get loose and hard and the tywrap will tighten them back up while allowing later disassembly.
