1986 944 odometer gear
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
The easiest way I found to get the needle off was to use a kitchen fork. Put some tape around the fork tines and cut a slot so the fork can slide under the needle and gently turn to the left and pry straight up.
Cheers,
Larry
Cheers,
Larry
Here are a couple of videos i did ,they are rubbish but it may give you a general idea of what to do.It covers dismantling the cluster,light prisms,odometer gear and changing the mileage.Hope it helps, http://www.youtube.com/watch?v=fNt3q9b4hbk and http://www.youtube.com/watch?v=yTb_V...eature=related
Lifetime Member
Lifetime Member
@Banshee: Don't sweat it, time of day is a big factor as well.
@OP: Recommend Rennbay -- they will not break, and if they do, you get another one.
http://www.rennbay.com/944-mph-odometer-gear-p-51.html
It is not hard to do, but just take your time and be patient, don't force it. If you're lucky, the old one is in pieces and just falls off.
