Video, does this look okay!!!
I have a couple quck questions for people who have a 944S or 944S2.
-In the first picture, you can see that the bottom chain tensioer pad has block off partially so I am replacing that.
Look at the two short videos.
In the first video....
1. Is that how much the chain tensioner should move? Is looks normal but I thought I should ask.
In the second video... >which is in the second post of this thread<
2. Is that how much the balance shaft belt should move side to side. That is how I found it when I took the covers off.
.....And sorry for the bad quality.
http://s271.photobucket.com/albums/j...t=P3131006.flv
It's hard to tell from your picture in the first post what you're talking about replacing. Could you take a picture from a little farther away, or get your camera to focus a little better? Your top pad looks pretty worn, though, so I assume you're referring to the bottom pad...
That seems like a lot of hop in the first video, though it's hard to tell with no oil pressure in the j-tube (since it's the oil's job to damp vibrations in the tensioner). Are all your cam teeth 100% okay?
