Removing 944 mirror 1986
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Check out the link below for removal and reinstalling of the mirrors.
http://www.clarks-garage.com/shop-manual/body-10.htm
Cheers,
Larry
Cheers,
Larry
If you are referring to removing the mirror housing from the car itself...push the whole mirror housing toward the front of the car to expose the screw. You'll see a small black plastic cap that is covering the screw head. Just pry the cap off with a small flat head screwdriver to expose the screw head. Be sure your wrench is fully engaged, those allen screws can be pretty tight and the heads can strip easily.
