Preliminary FS post (parts, not the car)
I'm going to be putting some stuff up for sale soon...just want to see what I can expect to get for some stuff..
Turbo S Control arms w/caster blocks and shot Ball joints
Axles with play in them (if you hold the axle you can twist the CV a bit)
Rear shocks - unknown mileage on them, less than 77k miles. They are bilsteins which is not factory for the rear of a 89 Turbo as far as I know so I assume they were replaced at some point prior to the 67k mile mark when I bought the car.
Reference sensor
Used Clutch/PP, was shuddering on boost in 2nd gear...should hold OK for an n/a clutch for a bit.
Water pump (core)
Also it seems likely I'll be getting rid of a pair of 17x8 ET 48mm wheels. BBS Moda. They will fit a car that is not lowered and does not have big brakes. A 225 size tire would probably fit up front on a lowered car, a 235 will not clear however. See here for pics (large pics). I may also be selling a pair of 17x9 ET 48mm wheels, same brand.
<a href="http://www.eden.rutgers.edu/~adrialk/bbs%20on%20car/" target="_blank">http://www.eden.rutgers.edu/~adrialk/bbs%20on%20car/</a>
<a href="http://www.eden.rutgers.edu/~adrialk/bbs%20on%20car/small/" target="_blank">http://www.eden.rutgers.edu/~adrialk/bbs%20on%20car/small/</a> for the best pics in a more 56k friendly size.
I may have some more small things...
Thanks,
Adrial
Reference sensor
Water pump (core)
Thanks,
Adrial
