Old school and a new alternative
The Cup Car motorsport setup was designed in 1985. It hasn't changed.
Here's a look at an AWESOME alternative.
<img src="http://members.rennlist.com/luke/moriss3.JPG" alt=" - " />
<img src="http://members.rennlist.com/luke/moriss4.JPG" alt=" - " />
From left to Right:
</font>
Here's is a short list of Pro's </font>
<img src="http://members.rennlist.com/luke/moriss5.JPG" alt=" - " />You can clearly see how the newer style Bilstein tubes are MADE for motorsports!- They dont even look like their street shocks. look at the weak looking joints on the bushing carrier for the cup tubes!!! <img border="0" title="" alt="[Eek!]" src="eek.gif" /> I am VERY interested in this setup, I got a quote....... this makes it even better!.........
the cup kits go for $1,585 right now............ this new Moriss kit $1,595.
Here's the full quote i received from Evan
Porsche 944 (street/track)</font>
Front Struts 600/180 valving
$420.12ea. $840.24(front)
Bilstein 46mm mono-tube steel threaded body coil-over shocks.
Rear coil-over shocks 565/218 valving
$242.84ea. $485.68(rear)
Springs $130-front
$130-rear
Total Concept 3 (less shipping) $1,585.92
If you have any technical questions, Moriss' tech GURU "Harry Larry" takes tech questions all the time during regular business hours at 1-586-873-2984
Evan can be reached at-
248.420.3084 -cell
evanmoen@morissdampers.com
<a href="http://www.morissdampers.com" target="_blank">www.morissdampers.com</a>
--It seems like a no-brainer to me...... I mean, 20 year old cup shocks, or Modern, tougher dampers that share parts with the 996GT3R!!!!
From left to Right:
</font>
- <font size="2" face="Verdana,Tahoma,Helvetica">similar tube to cup car shock</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">oe Boge shock</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Moriss/bilstein motorsport (924/44/68)</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">same w/o spring</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Moriss steel 944 strut ( owned by Van Stensin *rennlister* )</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">PRO's</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Front strut tube/tabs are stronger than cup kit</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">They are IT legal (unlike thread cup setups</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Infinite number of valvings avalible-from street to full out race.</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">the Rears are owner servicable!</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Spherical bearings- not rubber like the cup car's</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Uses TRUE Bilstein motorsport parts that were designed in 2003-not 1985</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Uses The SAME valving sytem as the 996 GT3R HOW cool is THAT!!! </font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">36mm Inverted Bilstein damper configured to Moriss specifications.</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">CAD-plated steel body with c-clip groove.</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Anodized Aluminum coil-over sleeve and spring seats for 2.50" ID race spring.</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Micro-cellular bump stop.
----------------------$368.79ea. $737.59(front)
46mm Inverted Bilstein SN series steel shock with c-clip groove hand built by Moriss.</font></li> - <font size="2" face="Verdana,Tahoma,Helvetica">Metric standoff's with CAD plated coil-over adapter lower fastener.</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">Annodized Aluminum coil-over sleeve and spring seats for 2.50" ID race spring.</font></li>
-----------------------$298.78ea. $597.57(rear)
Eibach ERS race spring</font></li> - <font size="2" face="Verdana,Tahoma,Helvetica">0900.250.0400 (400lbs/in rate) $65.00ea. $130.00(front)</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">0800.250.0300 (300lbs/in rate) $65.00ea. $130.00(rear) With torsion bar in rear</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">0800.250.0600 (600lbs/in rate) With-out torsion bar
------------Total (less shipping) $1,595.16</font></li>
Springs $130-front
$130-rear
248.420.3084 -cell
Lifetime Member
Lifetime Member
Luke,
This looks like exactly what I am looking for. I do have a couple of question.
1. The Bilstein’s rears look as if there is a valve on them, is this for adjustability? If so is this an air or some kind of oil setup.
2. This car is mainly for street but will see DE and AutoX when complete. Which setup of the three Bilstein’s would you recommend
3. If the shock is indeed adjustable with this valve, do you know of any set up to do this from within the car? Like having a firm, extra firm, insanely firm settings switch? Just a thought.
4. I am attempting to eliminate my torsion bars with a setup like this. Would you recommend any enforcement of the shock mount in the rear before attempting this?
Thanks in advance.
TaboII
Thanks in advance.
TaboII
1. The vavle on the bottom is for gasing the dampres up.
2. This setup is so good because it can vavled for the street/auto-x and when it comes down to full blown racing one day they can be revalved easyly
3.Not currently
4. Yes you can remove your t-bars and NO i would not reinforce you stock mounting points (its not needed)
The setup is not adjustable but I would rather
have a GOOD REPEATABLE non adjustable stup than a poor non adjustable unit.........
But the bilstiens can be made adjustable for
around 600.00 more for the set
3.Not currently
