Help! 951 dead..got spark but it won't start
Go out to hop in the 86 for a date tonite and it won't start. My brother borrowed it sun night and brought it home empty. Didn't drive it yesterday but anyway i figured out of gas so Iput plenty of 93 in it no avail. I don't have any power at the fuel pump fuse. the dme relay clicks when I pull it loose. Any suggestions? TIA Mike
Nerd Herder
Mike- Check out my thread for ideas..
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=017000#000000" target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=017000#000000</a>
Never drive a car with injectors dry! You may have to primer it; get gas into the system, before starting it.
As far as know, you can damage the injection system, if you don't reprimer the engine!
Hope that might help a little - heh, did that to my '95 vette, and that turned into a circus!
- Julie
- Julie
Heh, make sure the fuel pump works - sorry about that, no more ideas from me.
- Julie
- Julie
LOL I thought about that!!! He somehow figured how to turn the boost back up little ****head! Anyway where does the power to the FP fuse come from? I have no power on it. the ignition switch or a relay first? The DME doesn't have a hand in this does it? I know on fords and a few others I can manually run the FP with my genisys scan tool/reflasher I have GM reflash!I might pull the fuse box up and start checking a few things
Called my little brother bitched him out and took the fp fuse out hot wired it to run the car into my shop (it's raining) and took the dme relay out cleaned it up and soaked it with some wd-40 presto she works again!
