924S FUEL LINE LEAK
924S FUEL LINE LEAK
I am currently trying to find a solution to a fuel leak in my 1987 924s. There is a leak in the rubber on the fuel in hose on top of the engine. I have disconnected the fuel line from the damper, but cannot find anywhere the line disconnects until you get to the fuel filter. Any feedback as to cutting the line and how I would mend it back together would be appreciated. Also, if anyone has the fuel in line for sale, I might be interested.
If you cut away the crimp fittings from where the rubber hose meets the metal one you will find a push in insert head on the end of that metal line. You can buy some fuel line and hose clamps and patch it right back up. Chances are if one is leaking , the other one is not far behind so you should do them both. If you want some fancy looking stainless steel braided ones check out the site in my sig.
