What kind of tranny do S2's have??
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by 944S2NUT:
<strong> Hey your avatar is missing.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Thanks - that's how I can tell when the Paragon site is down
Here's an interesting logic progression.
1. Given 944/951 had 016 gearbox
2. Given that 968 had G50 gearbox
3. 968 can use other G50 gearboxes (911)
4. 968's G50 gearbox can be installed on 944/951
Therefore, doesn't it follow that a 944/951 can use ANY G50 gearbox???
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Danno:
<strong>Here's an interesting logic progression.
Therefore, doesn't it follow that a 944/951 can use ANY G50 gearbox???</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica"><img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
<strong>Therefore, doesn't it follow that a 944/951 can use ANY G50 gearbox???</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Would you use a 944/951 or a 968 torque tube then ?
(remember Nicolas' post in the Turbo&S forum ?)
Quote from Chris Fisher at Powerhaus II:
"The 968 is not a G-50 gearbox, but is a completely separate gearbox
applicable to the 968 series cars. It is an excellent unit, very beefy and
nicely engineered."
As I remember the diffs are the same in the 968 and G50 boxes so you can use any of those diffs.
--Brian Morris
89 951
nicely engineered."
--Brian Morris
89 951
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Roy LaZelle:
<strong>Was the problem with the 968 differential due to installation or design ?? --Roy--</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I think the factory used a bad batch of torque wrenches.
Just out of curiosity how is the 968 pinion bearing preload set (shims ???). I had quite bit of experience mis-setting the preload on my long departed Volvo 122S <sigh>. The preload was set with shims on the rear wheel bearing carrier. In my case it ruined several wheel bearing before I figgured out how to do it... (which was .004 inch freeplay with a dial indicator after tightened down). --Roy--
