Are 924S spindles early or late offset?
I am looking for some late 87-89 Spindles and hubs for a late offset race car. A friend has some from an 88 924s. Are they late offset? Are they the same as the late 944?
Thanks, I didn't k now they still used the old spindles on the 88 924S. BTW: My current Race car uses a spindle with the speedo cable hole and has run for at least 6 years that way. My problem is that i am building a late offset race car and have only early spindles and hubs lying around.
Former Vendor
@PorscheDude1;7350633]
Yes, you can use late spindles, hubs and struts with with early offset control arms and tie rods.
@johntorg
Here is a thread on 924board with detailed info on the various permutations of spindles and hubs: http://www.924board.org/viewtopic.php?p=236428#236428
@johntorg
My advice is to check the spindle for cracks any time you change the front rotors. When I look at my spindle I could see it was cracked for a long time before it failed. In fact I has just complete a race the day before without issue. First lap out the pits the next morning it broke.
So when you change the rotors look for cracks. You many need to use a type of penetrant inspection.
Don't risk it. I know a lot of people have used these on track cars, but with race-rubber and suspension upgrades...it's a lot of stress on the hollow spindle. Lives are at stake and there are parts houses full of solid spindles for cheap. No self respecting race car has a speedometer anyway.
Is there a solid spindle that mounts to the Konis used in the early offset 83-84 cars. I have an 85.5 944 Parts car which should have a solid spindle. Does anyone know if this will interchange directly?
