dme connection
dme connection
i unplugged the dme recently and found that there are 2 of the 35 copper clip/connectors missing on the main plug. is it supposed to be this way? cause those 2 pins would not be making contact, i will check tomarrow so i can tell you which pins they are exactly . i have narrowed my recent no start/intermittent crappy idle to this plug connection and if i unplug and plug it back in it will idle good, but over time it will get crappy and not start until i unplug and plug it back in again. also the pins on the dme itself are not corroded looking and i refloated the dme solders too. this is an 87 n/a 8v
thats normal, looking at a dme connector right now and with the wires aimed to the right the 4th and 5th holes are empty on the top left of the connector. the connector was from an 88 na
thanks, i believe those are the holes i was talking about. im about to go work on my car now so ill check the wire connection in the plug itself and maybe i should just replace all the copper connectors anyways.
You could hit them all with something like "de ox it" and work the connector a little bit. That stuff can work wonders.
http://www.all-spec.com/products/Cai...-00/D5S-6.html
