head gasket
1 Post
head gasket
I am getting a 951 motor with a blown head gasket I am curious if 924s 944 and 951's all used the same head gasket. I am going to leave the motor stock for about a year and then upgrade it to ~270 crank horsies. Also I am wondering if the stock head gasket is fine or if I should go with a widefire gasket.
Also if some of you knowledgable ones would give me a rundown of what all seals/gaskets I need to replace, I would appreciate it.
Also where are good (read cheap) places to get the gaskets of choice.
Thanks in advance for the help. <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Simple, get a widefire head gasket set from <a href="http://paragon-products.com" target="_blank">Paragon Products</a> for a very good price. It has everything you need to replace the front seals. Change the belts too. It might be a good idea to do a waterpump and rollers if you do not know the history on them. Kind of a "might as well while you are in there" type of thing. This way you are up to snuff for the added power in the future.
Widefire is a must if you are raising boost. You will have a better seal, but can still burn it up if not tuned right.
