86 944 n/a will not start with key
have changed out starter/sol, ignition switch and relays, turn key on and will start with a starter button, key does not engage starter, where else to look
stephen
stephen
To help identify what part of the circuit it is I would disconnect the white 2 pin connector around the brake booster and have somone hit the key while you check for voltage, one goes to the alt, the other goes to the starter solenoid. Then you would know if its the starter or the wiring.
