starter problems
Old Sep 13, 2002 | 12:31 AM
jfc's Avatar
jfc
7th Gear
Red face starter problems
My 1984 944 starter does not turn over the engine when I turn the key over. I try it over and it turns over after a while or after turning the key to the off and back to start position, it has happened when the engine is hot or cold, I believe the battery is good. My plan is to take out the starter and solenoid and clean them. If I have to replace the starter, can anyone direct me to where I can purchase a reasonable rebuilt starter.
Old Sep 13, 2002 | 12:56 AM
Type_LT's Avatar
Type_LT
Post
The starter is easy to remove, if it hasn't been off for awhile then put some penetrating oil on the two bolts that hold it on (17mm I believe).
Buy a starter here:
<a href="http://www.paragon-products.com/" target="_blank">Paragon Products</a>
Old Sep 13, 2002 | 02:05 AM
adrial's Avatar
adrial
Post
Could be your ignition switch...
check to make sure the starter is getting power while you're down there...
Old Sep 13, 2002 | 02:52 AM
Olli Snellman's Avatar
Olli Snellman
Post
There's no need to buy a new starter.Rebuild kits are available.I bought one, it cost only couple of €/$.It's rather easy to do by yourself.The whole "project" took only about two hours.
Olli
'88 951
Old Sep 13, 2002 | 12:09 PM
stefang's Avatar
stefang
Post
[quote]Originally posted by Type_LT:
<strong>The starter is easy to remove, if it hasn't been off for awhile then put some penetrating oil on the two bolts that hold it on (17mm I believe).
Products[/URL]</strong><hr></blockquote>
19mm and you'll need a box end wrench. Not enough room to get a socket on the right bolt.
Stef
