Moving around late-style guages?
Did a search on this, and I can't believe no one has asked.... I've got a Momo steering wheel, which I REALLY prefer to the stock wheel, but I'm getting tired of bending down to see the 50-90 mph range on the speedo. Plus, I don't like taking my eyes off the road for that long. I was thinking that if I could switch the tach and speedo and rotate the speedo counter-clockwise, I'd be able to see everything up to 120 mph or so just fine. Is this possible on a late-style instrument cluster? Anyone tried it? Thx!
The gauges are powered via the membrane on the back of the cluster. If you were to switch the gauges, they wouldn't receive correct power. Also, either the tach or the speedo have a recess behind it that houses a piece of the gauge. I don't think this would be possible.
OK, I'm gonna get flamed here... or be hailed for thinking "outside the box"..
YES it can be done, and it is easier than you might think...
1) disassemble the gauge cluster to the point you have the back off the front (with all the gauges still attached to it)
2) remove the speedo needle
3) remove the FACE of the speedo gauge
4) scan the speedo face using the best resolution your scanner will manage
5) using photoshop or some other editing software move the speedo numbers to where you want them relative to where they are now (so the odometer will remain usefull)
6) print your new face and bond it onto the old one
7) cut the printed face to match the old one..
8) reassemble, but put the needle back on in the new orientation
switching the tach and speedo takes a little more work, but it can be done.. we have the technology... that is if you have BASIC soldering skills you can make it happen.
ask me how I know... pay attention to the gauges in the video.. I know the video SUCKS, but it shows my gauges, and yes that is a mechanical gauge, I am working on fine tuning a electronic to replace it, but look over on the right side... all the factory delivered gauges are still there, just in different places... I also took the liberty of deleting the KPH marks "while I was in there..."
http://www.renntube.com/videos/13/mu...r-camera-mount
Holy cats, thanks for the tip, but that's a bit more ambitious than I'm feeling right now. I was kind of hoping for an easy swap. Though you've given me an idea.... If I could move the numbers further inward, closer to the center of the speedo, that would solve my problem.
having the AM boost gauge and WBO2 are very useful when tuning, but I don't like the A pillar mount, and below the radio really isn't very good as you have to look down to see them... having them siamesed into the cluster puts them right there with the rest of the gauges... I have liked it so far, just need to wrap em up..
Good Luck!
I had the identical problem.
I solved it by lowering the DRIVER SEAT.
Especially if you are a tall person, you could also move the steering wheel away from the gauges by adding a Hub/Wheel Spacer.
Or try something like the JWest Engineering Steering Eccentric Adapter (www.jwesteng.com/porsche/steering.htm).
MN
MN
