Can a block bend sitting on an engine stand?
#31
Someone just put an engine on a stand, and reply to this thread in a few years. Problem solved.
If it does, or doesn't happen, how long has anyone here had an engine stored on a stand? If its taking you years to build an engine, I would worry about the assembly lube turning to liquid and running out of the bearings and bores LONG before I would worry about the block tweeking.
Is this even worth talking about?
#33
As a degreed and employed ME, I dont believe aluminum alloy pressure castings are subject to creep distortion below about 300 deg F. Certainly not at room temperature and certainly not at the low stresses that would be induced by the block's own weight.
And this aspect of materials science/engineering is pretty well known and studied, so auto manufacturers are not going to make engine blocks out of some poor material alloy that is subject to creep at low temps and stresses.
So, call it call it closed minded, but I am still saying this is a non-issue.
Your whole post is not close-minded at all, what is very foolish though is how you came across the first time to where you acted like you knew nothing at all about the situation, and then calling it utter bs when i am sure you easily could have typed your last post which probably didn't take that long.
That is all.
Edit: Somehow, the last 5 posts or so have been what we should have had in the beginning. Instead of a bunch of useless trolls posting everywhere giving their 2 cents, its nice to have a somewhat intelligent discussion about it. Congrats, you saved the thread lol.
#34
So anyone who posts a vote on a subject that everyone agrees is silly is automatically a useless troll? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I think leaving a block on a stand for a long time is OK. But if you're absolutely paranoid, couldn't you just turn it over on the stand every few weeks?
#35
I built my spare engine in an egine stand. I then left it in the stand for 2+ years before I installed it. Once installed... I ran perfect.
Guys metal can creep and metal can elasticly deform. Metal creep occurs at high temps. The temp needs to be some 75% of the melting temps at minium. However the actual creep characteristics are very dependant on the alloy, loads, and temps so 75% thing is very rough guess.
Point is temperature of a garage even in the Phoenix heat is too low for creep to be an issue. Plus the only load is the static load. Again not enough load.
The block can elastictly deform. Elasticly means it moves, but when the load is changed it moves back like nothing ever happend. Not I am not certain what might happen if you ran the engine with only the bell housing supports. It might not run right due to elastic deformation. Even so we don't run engines on stands so that is a non issue. The engine will turn over by hand just fine so even then my guess is there is not enough deformation to cause issues.
The real danger is plastic deformation at the bolt holes if you put too much weight on the end the block. For example if your bolts are not tight and you hang off the end you could bend the bolts (if you are lucky) or bend are of the bolt holes. Given the engine is 350-400 lbs adding another 200 off the end is not good, but probably is still ok.
So bottomline is you think it can damage it are not even close to being right.
#36
Well um, i have explained the difference between posting a vote and then making yourself look like an *******. Trust me, if i hadn't mentioned anything i am sure Frporscheman that you would not have replied in as lightly as a way as you just did.
Theres a big difference between flaming just because everyone else is doing it and inputting your opinion. But hey? At least we know one thing for sure, i think we've established that engine blocks cannot bend ENOUGH to keep the engine from running, someone should tell that guy in the other thread.
#39
So by virtue of giving a curt answer, or agreeing with someone that gives a short answer, I am a close-minded, ridiculous, foolish, know-nothing *******?
#41
Still plays with cars.
Now that we've settled the engine block question, should I worry about my mufflers bearings while my car is stored over the winter? I changed my blinker fluid before storage so I'm confident they will be OK.
#42
i dont understand. If i say "it cant happen" and you say "it cant happen because................................................................. ........"
Whose more right? is that what your arguing?
#43
I think the "flaming just because everyone else is doing it' is the funniest stuff. The original post was well answered. The intervening humor was enjoyable. Facts and fun.
#44
Some people are at different levels of knowledge base, one of those being the knowledge or basic idea of how strong aluminium really is compared to its stronger steel counterpart. Thus, a warped block isn't that far fetched for some people as it is others. Josh better give me a damn cookie after explaining all this lol.
#45
