Replacing front wheel studs - hard or easy?
6th Gear
I need to replace the front wheel studs for longer ones to accommodate spacers. How difficult is it to remove the factory studs? Is it something that I can do at home or does it require a mechanic with special tools?
Will the wheel bearings need to be replaced in the process?
