slow speed fan resistors
Old 01-16-2010, 05:01 PM
Bruno'S2
Bruno'S2's Avatar
Default slow speed fan resistors
My cooling fans are still not running on low speed even with a new relay. I suspect the slow speed fan resistors to be the culprit. Clark's is talking about that resistor being on the firewall behind the glove box. Does anyone know where I can see a picture of what this thing looks like or a good enough description so I can check the right part? There's a bunch of electrical stuff back there.
Old 01-16-2010, 05:15 PM
Bri Bro
Bri Bro's Avatar
If the fan is running on low speed, the resistors are fine. The low speed resistors are bypassed ( the relay just puts a short across the to leads of each resistor) when running high speed by the fan relay.
Old 01-16-2010, 05:19 PM
Bruno'S2
Bruno'S2's Avatar
Thanks for the info Brian but my problem is that the fans DO NOT run on low speed...never.
Bri Bro
Bri Bro's Avatar
What year is the car? That one word got me ...NOT
Old 01-16-2010, 05:22 PM
Bruno'S2
Bruno'S2's Avatar
It's a 1989 S2
Old 01-16-2010, 05:30 PM
Bri Bro
Bri Bro's Avatar
In 86, the resistors were in the car by the glove compartment. In 87, they were put in the engine compartment under the plastic cover above the firewall, next to the battery. I haven't looked at a 89S2, but I would guess they are in the same place as the 87. If you have not seen them before, look for two hockey puck sized objects mounted on a metal plate.
Everything you need to troubleshoot the fans circuit is at the fan relay. Both side of the resistors come into the relay. The terminals on the fan relay for the resistors are V1 and M1, V2 and M2. The resistance of the resisters is 0.9 ohms but with the wires it will be between 1 and 2 ohms. Just pull the relay out and measure those terminals.
This is what they look like on an 86. After they move it into the engine compartment, they dropped the little round black parts which were thermal limit switches and just have the two puck resistors.
https://rennlist.com/forums/attachme...t-im002964.jpg
Old 01-16-2010, 06:41 PM
Bruno'S2
Bruno'S2's Avatar
I just measured the resistance between M1 and V1 as well as between M2 and V2 and I get infinity. Looks like the resistors are to blame but still can't find those. Looked under the plastic cover around the battery and under the dash behind the glove box. Don't see anything that looks like that
Old 01-16-2010, 07:08 PM
Bri Bro
Bri Bro's Avatar
Found this for the S2:
https://rennlist.com/forums/5842457-post10.html
The resistor pack on the top of the blower motor are for the internal fan motor. Look for the pucks. There true name is a disk resistors.
Old 01-16-2010, 08:59 PM
Bruno'S2
Bruno'S2's Avatar
This is weird, I do see pictures of the 2 resistors behind the battery just under the base of the windshield but that's not where they are on my car. I will take a look again under the dash being the glove box because the wires I see on the pictures going to the resistor is going through the firewall in the cabin on my car. So the resistors must be under the dash.
Old 01-16-2010, 09:13 PM
Bri Bro
Bri Bro's Avatar
Did the low speed fans ever work since you have had the car?
Old 01-16-2010, 09:16 PM
Bruno'S2
Bruno'S2's Avatar
I don't think so, I've notice only this year when I started doing some DE. I also removed the valve cam cover and I think I have over heating damage...the paint is pealing off.
Old 01-16-2010, 09:25 PM
Bri Bro
Bri Bro's Avatar
I am thinking that someoned remove the resistor packs. I would be very surprised if you find them inside the car since they were moved to the engine area in 87. The link in #8 is for the same year and model as your car. The connections to the resistors are spade lugs, see if you find four of them tucked away.
Replacement disk resistor
http://www.944online.com/cgi-bin/ASI...ingsystem-9442
Picture of mount.
Old 01-17-2010, 06:19 PM
Bruno'S2
Bruno'S2's Avatar
Well Brian you where right... Took my son to find those but they where just being the battery underneat the windshield edge. And take a look at the poor state those are in. I have some electrical work to do replacing those overheated wires
Old 01-17-2010, 06:59 PM
Bri Bro
Bri Bro's Avatar
Glad you found it. Those wire look cooked, a real common problem. Those resistor get real hot. I would guess about 100 watts of power is dropped in them.
Old 01-23-2010, 09:43 AM
smokin_944
smokin_944's Avatar
Years ago at 944online there was a thread on the cooking of the wires leading to the resistor pack. Common problem on later year cars. Bon travail Bruno! Good work! On to the next issue.
Quick Reply: slow speed fan resistors
