is flasher relay porsche or anywhere part ?
Anywhere part. Just make sure you match the layout and numbers on the output posts, get an electronic one rather than thermal, and a normal duty rather than an heavy duty truck one designed to drive a bunch of signal lights. Should be about 10 bucks.
Hey Art,
Be careful, because I bought a flasher relay that had the same prong layout, etc. from a local parts store and it didn't work. Text on the outside of the box said it would work on any Import with that prong layout. So much for truth in advertising!
Good luck!
Good luck!
