Sloppy Second
Sloppy Second
And first and third, fourth and fifth gears that is.
The hole in the gear shaft rod has become oval shaped. The shift lever its self is fairly new and its pin is still round.
Has anyone found a fix for this oval hole problem? Is there a way to bush the hole or should I replace the gear shaft rod?
Another project!
Thanks, Steve Frew.
'86 951
Another project!
Thanks, Steve Frew.
'86 951
