Reading engine fault codes
Old 01-02-2010 | 08:32 PM
Airflite40's Avatar
Airflite40
Official Rennlist
Borat Impersonator
Default Reading engine fault codes
I have read that there is a way to get engine fault codes from the 1991 S2.
Something about holding down the accelerator while turning the key to 'On' but i can't find the exact procedure...
Old 01-02-2010 | 11:09 PM
mj951's Avatar
mj951
Not sure if this will help or not...http://www.lindseyracing.com/LR/Parts/BLINKCODE.html
Old 01-04-2010 | 01:55 PM
wiseman's Avatar
wiseman
On a 968, you turn on the key, hold the gas peddle down for 3 seconds and release SLOWLY. If there are fault codes, the "check Engine" light will start to blink a combination of short and long blinks. 968 Forums has a list of the codes. I would thinkl they would be the same.
Quick Reply: Reading engine fault codes
