Danno, what's the link to your tip on retarding timing again?
Danno, my car pings just a tad under full boost (~1 bar). This is despite perfect tune, the best gas I can find, etc.
I know there's a way to retard the timing just a smidgen, there's a little screw thingy on the DME brain. Do you still have those instructions posted somewhere? Do you have a suggestion on which setting to try? The car only pings under full boost and a slight 'lugging' situation (in too high a gear when I floor it). And the car has Autothority Stage 2 chips. Will the adjuster still work?
thanks
thanks
The info I was looking at was at <a href="http://members.rennlist.com/951_racerx/" target="_blank">http://members.rennlist.com/951_racerx/</a>
It's good stuff. I am going to try position 5 and see if the pinging stops.
